Backup cam
Ddog1
Anyone know which cable connection controls backup cam?
2010 gen. 4.6
Thanks
I don’t remember exactly which one. You have to remove the trunk lining cover. It is easy to locate the wiring harness once you take the cover off.
You can also check out this video
It should show you where the connection is. Hope it helps.
Thanks for the quick reply.
I'll check.
Before I do would you happen to know the connection at the nav. unit for backup?
I had the nav system repaired after it failed at Hi-tech in van Nuys CA. Backup is the only thing that doesn't work.
I'll check.
I don’t know about that one, sorry. It sounds like your car’s computer may need to be reprogrammed. Have you brought your car to the dealer? Is sound system working?
