OBD Port for Bouncie Tracker
Doug Richardson
Has anybody ever connected a vehicle tracker on a 2015 Genesis Sedan? The OBD is super close to the access panel and it will not allow for reattachment if the Bouncie Tracker is installed. I tried sending it back and they sent me a photo that the OBD port could be removed and installed loose. Before I try this I would appreciate another opinion.
Thank you!
Do it as they says....pop it out and connect the Bouncie. I have the tracker hookup in my daughter's Santa Fe (don't ask why, lol) and it works fine! :D
As for the Genesis....I got something else connected and I had to remove it from the little bracket, otherwise access panel wouldn't stay in place. I can take a picture and show it if you like.
That would be great if you can send a picture.
Actually. You'd have to push it in to remove it from the bracket. Plenty of room to plug in something else and close it.
I'm using my phone now to post it, I hope it works.
Either pull it out (I did this to fit a wifi hotspot) or get an OBD extender with a 90 degree head.
Thanks for all of your help...tracker is installed. Happy New Years!!
