Turn off stability control and.......
salcirabisi
Panama City
Equus (2011-2016)
buckle up and hold on!
Good lord I couldn't believe how much control the stability system had when u push on the gas pedal. Car always hesitated when stomping on it.
Fuel efficient? I think NOT!
Fun! Oh hell yes!
You mean how it shuts the system down when the tires break loose? Just be careful shutting off the control system, especially on wet roads. I've only got the 3.8 engine so not a lot of rubber burning going on here.
You probably already know this but you can fully defeat the stability and traction control by holding that button until you see the message displayed that they have both been defeated. I'm glad Hyundai put this feature in as my previous Genesis required a hardwire mod to achieve this. Together with Sport mode and you're set for some serious racing fun! Enjoy!
As you said, if we simply press the button, traction control is turned off. If we press and hold, that and stability control are turned off.
Traction control being off allows the tires to spin, but what does turning off stability control allow? (other than a convenient way to wrap your car around a tree)
There's a lot Stability control (ESC) can do and one of them is it can reduce engine power or operate the transmission to slow the vehicle down, like if it thinks the car is skidding. Due to the fact that stability control can be incompatible with high-performance driving, many vehicles have an override control which allows the system to be partially or fully deactivated. (from Wikipedia)
From the Equus manual: The ESC system is to stabilize the vehicle in cornering maneuvers. The ESC monitors your steering and driving. The ESC applies to a brake of an individual wheel and engage in the engine management system in order to stabilize the vehicle.
So in a racing situation you want both the Traction Control and ESC defeated and the tranny set to sport for the best performance this car offers.
The Equus does not have the driving dynamics for high performance driving....the steering, suspension and chassis are just not set for it
The Equus is a cruiser...be careful
Are you sure you would not be better with a BMW M?
Warren
Ok so I have clicked and held the ESC button. It only pops up that the ESC is off but not the stability control.. and if I do get it to cut off how do I cut it back on
Your car may be different, but if I recall correctly, press it once and you should see a yellow warning light appear on the dash. Now, press and hold the button for a few seconds and another light should appear. At this point, both systems are off. I think if you press it again, both systems come back on. If you turn off the engine, both systems default to on.
Disclaimer: note the warnings in the manual. Driving the car with these systems off can cause an accident.
See the attached, it's in my 2019 G80 manual.
