MAM
- Dec 1, 2019
2016 3.8 AWD Hyundai Genesis
I decided to start a new thread since the previous one has so many pages of entries going back several years.
I have similar symptoms and have tried many fixes described in the previous thread.
It started with a small vibration between 25-30 mph, accompanied by a fluttering sound that seemed to be coming from the center console area.
First dealer replaced a bent wheel, no change. Second dealer replaced the drive shaft assembly. The caused the flutter to go away but it was replaced by a stronger vibration at exactly 28 mph at cold start, which goes away after about 10 minutes of driving. The dealer then did a force balance and added a 2 washer shim, again without result. They recommended replacing my new Kumho tires with original Michelins.
I have seen on the other thread that these issues happen with the original tires as well so I do not give any credence to that.
At this point, unless someone has a fix that actually works I am going to live with this and try to avoid driving at that speed during the first ten minutes. I have found that placing the car in Sport mode makes it easier to drive 25 mph in my neighborhood.
