AFLS module location 2011 4.6
Jerziboi
Can someone point me in the direction as to where the AFLS module is located.... Thanks
The afls module is under the crash pad next to the speaker in the front.
Thank you I assume it can be reached after removing the head unit?
You can access it by removing the glovebox. Thats how I replaced the module for the LED one. There are two screws, the inner one is a b***# to remove. You have to have the right tool that is short or small enough to remove it.
Do you take pics of it.
Thank you I will attempt to replace the module this weekend if not I will just pull the fuse out because the flashing light is annoying
