throwawaygenesisbaby
- May 29, 2020
- No Genesis Yet!
So I found this 2015 hyundai genesis for a good price. It is single owner with 75k miles and the carfax doesn't have anything suspicious. However, a pre purchase inspection yielded the following:
The car fax should very regular services at Hyundai till the 35k miles point and is completely blank after that. The car is price about 1000 below KBB.
Please let me know your thoughts! Is it a pass or should I consider it?
- CODE U0101 (LOST COMMUNICATION WITH TCM) FOUND IN HISTORY. - maybe a repair in the past?
- FOUND ACTIVE CODE U0109 (LOST COMMUNICATION WITH FUEL PUMP CONTROL MODULE - seems like a module needs replacement?
- The car was found to test drive fine. No veering, vibration or hesitation.
- Potentially concerning, the shop which did the PPI asked me to check the carfax for 'possible water damage' as they said there a strange build up around the trims etc. of the car. I have attached some pictures. If you own the same model, could you let me know if your car has similar build up?
