2015 3.8 Sedan- Water leakage
GSS
I have a question just wondering if any one experienced same problem, today I noticed water dripping inside from front left A-Pillar, not sure if there’s been a recall for this or the roof drain is plugged.
Any help is appreciated, thanks in advance guys
cheers..
cheers..
I haven't heard about that one before - might be a plugged drain. I'm sure others will chime in.
Thank you @skipgen, I hope this leaking won’t cause any major problem because it is raining and will be raining till midnight :rolleyes:
cheers..
Like mentioned above, I also guess that it could be an sunroof drain hose issue. Best case it will just need to be reattached by only removing the A-pillar trim to access it. Worst case, the hose split and will need to be taped with water proof tape until the hose can be properly replaced to minimize the water intrusion.
You can also try clearing the sunroof drain holes of any blockage in case the water is just pooling in the sunroof due to a blockage and flowing down into the cabin by way of the pillars.
Thank you @carguy75 yeah that could be the case, there must be some blockage. Is it easy to remove the trim without breaking any tabs or damaging the trim itself ?
I believe that the pillar can be easily pried off with a panel tool, however I have not removed my pillar on my Genesis so this is only speculation on my part. However, in most cases the A-pillar trim can be pulled off without much effort.
