It is and feels very very nice. And it’s not quite that much of work!!! It’s doable!!!Looks really nice. Looks like a lot of work
Not to sure if I would have the patience for that . I must say it looks nice.Job well doneIt is and feels very very nice. And it’s not quite that much of work!!! It’s doable!!!
Not to sure if I would have the patience for that . I must say it looks nice.Job well done![]()
A few days!!! But well worth it!! I don’t think you can find anything like this to buy for this car! That’s why i decided to do it myself! If you’re interested let me know!Looks awesome. Honestly, been looking for something like that since I bought the car. That does look like a lot of work though
Im really interested in getting this done!! Also how hard was it to do carbon on the center controls?A few days!!! But well worth it!! I don’t think you can find anything like this to buy for this car! That’s why i decided to do it myself! If you’re interested let me know!
What center controls??? Steering wheel controls??? Not that hard!!!Im really interested in getting this done!! Also how hard was it to do carbon on the center controls?
sorry meant to say the shifter bezel and cd player bezel. I found some carbon fiber on amazon but im a little skeptical on the qualityWhat center controls??? Steering wheel controls??? Not that hard!!!
Everything is preety easy to take off the car! Staright forword. Just be careful of the wires hanging beneath the shifter bezel! As far as the carbon fiber goes, if it’s a little more expensive it’s a lot better and in the endit saves u a lot of time. Much easier to work with! I’ve worked with cheap carbon fiber, it’s a pain in the ass!sorry meant to say the shifter bezel and cd player bezel. I found some carbon fiber on amazon but im a little skeptical on the quality
Furthermore, the resin is just as important. Use a good quality one, use the proper measurements and allow it plenty of time to dry. Don’t work in high humidity (a rainy day for example). Be patient!Everything is preety easy to take off the car! Staright forword. Just be careful of the wires hanging beneath the shifter bezel! As far as the carbon fiber goes, if it’s a little more expensive it’s a lot better and in the endit saves u a lot of time. Much easier to work with! I’ve worked with cheap carbon fiber, it’s a pain in the ass!
Thank you!Wow that looks awesome
First of all thank you! And yes, it’s all dry weave CF, manually wet layup and drip dry + a lot of sanding after!! It’s not that hard, believe it or not this was my first steering wheel that i’ve done. I never worked with pre preg, I don’t vave an autoclave or anything like that, and no wrapping or bagging. I’m curious to work with pre preg but don’t you need an oven (autoclave) for that...high heat? Anyway if you like it you should give it a try, it’s easy and very satisfying! And just in case, this is how my car looks now!Looks really nice. You used dry weave CF and did a wet layup manually? I work in the aircraft industry and we use pre-preg CF on certain parts and then bag and autoclave to cure. If you did a wet layup it sure looks uniform and even for resin coating. Did you wrap the wet resin layup in anything or let it drip-dry basically? You were very meticulous in this process with the outcome looking great.
Still working on a front lip +diffuser made from a lip for the Genny coupe, CF trunk spoiler and i really want to make a AMG style rear diffuser with the trapezoidal exhaust!!!First of all thank you! And yes, it’s all dry weave CF, manually wet layup and drip dry + a lot of sanding after!! It’s not that hard, believe it or not this was my first steering wheel that i’ve done. I never worked with pre preg, I don’t vave an autoclave or anything like that, and no wrapping or bagging. I’m curious to work with pre preg but don’t you need an oven (autoclave) for that...high heat? Anyway if you like it you should give it a try, it’s easy and very satisfying! And just in case, this is how my car looks now! View attachment 29808View attachment 29809
