Seems to me my Genesis should have been provided with two Smart Keys. My Genesis only came with one and another one costs about $300 with programming. How many Smart Keys did you other owners receive with your Genesis?
The Owner's Manual suggests that if you lose a Smart Key, you should have the vehicle towed to the dealer. From the middle of the Sonoran Desert?? You could die first!
My suggestion: If you don't have someone with you to carry a second Smart Key, keep a second Smart Key somewhere accessible inside the car. It must be wrapped in aluminum foil so it will not be able to transmit its signal. I tried this ... it works. If you are in a situation where you might lose your primary Smart Key, remove the mechanical key and hang it around your neck or belt and use it to get into the car. Then retrieve the second Smart Key and remove the foil to start the car as usual.
