Navigation System
Strawboss
Got a jump on car after jump Nav system dont show no more it flicks likes it's trying to come on screen. Can hear Audio but everytime Nav flicks it stops Audio then after it stops flickering Audio continues.. My question is it a way to reset Nav or a Fuse to replace ??? Never had a problem with it til I got that jump???? Thk u
Why did you need a jump? If there was a problem with your battery or charging system, did you get it fixed?
My battery was completely dead when I got the jump it blacked out the nav system put In new battery cant see nothing on screen to try to reset back up camera not showing as well. But audio works ...NEVER HAD A PROBLEM WITH NAV IR BACKUPCAMERA UNTIL THE JUMPSTART ANY SUGGESTIONS THK U
I'd disconnect the negative battery cable for a minute and then reconnect it and see what happens.
Thks for responding now I'm mew to this do I have car crunk then disconnect negative or dont crank remove only negative?? But if I do wont it drain battery?? Thks
Did you read the link I supplied?
Yes I read the link I was only asking now if u into YOUR feelings on responding PLZ DONT RESPOND AT ALL OK THK U
Not if it is disconnected. Just take the negative cable off, wait a few minutes and put it back.
Did you ever get your problem resolved?
