Hyundai Service CANADA
Waki
Southern Ontario, Canada
Called my Southern Ontario Hyundai dealer today to book a 24,000km service. I supply oil ( synthetic ), have rear snow tires ( no rotation nor balancing ) $295 !! They are nuts.
Getting it all done locally for under $60 !! Incidentally, the cabin air filters,
($40 here in Canada ) are $8.50 on E bay. Hyundai just don't get it.
Have to say I've been totally dissatisfied with Hyundai Canada & the dealers. VERY poor, unimaginative & unskilled. May even make me rethink another Hyundai
Clearly, this is dealer-specific thing. I've had my oil and oil filter changed several times now for a little over $40 (oil, filter, labour incl). Good courteous service done in less than 1/2 hr (live in the West Island, Montreal). I suggest you try another dealer.
In my case, I have always serviced my car at a different dealership from where I purchased the car simply because they are closer to my home. Never had problems doing that.
Ah....but that's NOT the 24,000km check. Why it includes $88 to inspect the brakes !! Just wait. $18 to lube the throttle body ! Almost $30 to inspect the hoses etc !! :eek:
Not all periodic services are created equal. Supposedly they're supposed to match the manufacturer's service schedule, but often the services don't match up with the milestones or include a lot of stuff that's unnecessary (or has a generic "if applicable" to the vehicle notation).
What does your dealer's 24K km/15K mi check include?
It's not Hyundai's fault, it's the dealer. Check your maintenance schedule manual to see what work is required to be done, rather than what the dealer *recommends* being done.
Dealer maintenance schedules generally include a bunch of ad on services that Hyundai doesn't require.
Yes the 24k service is a fairly expensive one, but since the regular oil services are only about $50 I'm certainly not complaining. The 24k includes the Brake Service which involves disassembling, cleaning and lubricating all four brake calipers. The Air Filter is changed and a number of other inspections and service items are checked. All this for $250 more than a regular oil service (which of course is also part of the 24k), I don't consider that expensive. BTW my dealer rotates my tires at every oil service unless I ask them not to. Your experience is the total opposite to my own. I find my dealer knowledeable, helpful and cooperative. Going outside the dealer network for service, could compromise your warranty.
Now if you want to see expensive, try a BMW Dealer Inspection 1 or 2 for a bank account draining experience!!:D
ACTUALLY going outside the dealer network can not & does NOT impact your warranty. You can ensure little things get done. You just keep a written record of it. I have not & will not use dealer service....ever, except for recalls. ( 5 new cars )
OK.....so why did you call them about booking the 24K service then. I'm confused :confused: (admitedly not an unusual state :).
