Gentlemen,
2015 v6 3.8L RWD Genesis: Condition:
- Mileage = 92,500 Miles which is about 149,000 KM.
- Warranty: Expired
- Car very well maintained, regularly.
- All fluids changed (Engine Oil, Radiator fluid, Brake Fluid, Diff Fluid)
- All filters changed.
- Transmission fluid completely drained and filled 3 times in a few days in the dealership with new pan.
- Zero codes in scanner; system check: OK.
Situation:
- Hard shift or slam-like shift from 4th to 5th gear with more than gentle throttle applied. Hence I performed the above service.
- While pushing pedal with (let's say) 15% throttle, Hard Shift b/w 4th and 5th gear is very apparent.
- While changing throttle positions (i.e., very gentle acceleration, shifting is very smooth), or (i.e., more than 1/2 throttle, shifting is smooth too) between these two gears.
Action Taken:
- Transmission fluid completely drained and filled 3 times in a few days in the dealership with a new pan -- same issue persisted.
- Added a bottle of Lubegard Red into the ATF fluid -- same issue persisted.
My own analysis:
- A bad shift solenoid that is clogged or dirty.
- A bad throttle position sensor? (no codes in OBD scanner though)
- Speed sensor?
- Valve body?
What do you guys think the best course of action is? My last resort is to pay for a full Transmission replacement which I am trying to avoid by carefully eliminating the problem.
Let me know your thoughts.
Thanks,
Husam
- Warranty: Expired
Situation:
Action Taken:
My own analysis:
- Speed sensor?
- Valve body?
Thanks,
Husam
