gpjlytham
Hi All
My A/C works great on the freeway but not so great sat at a stop light, so I opened the hood to look to see if the compressor is turning on or off and it is ALWAYS ON?
The radiator fan appears to be working fine and moving lots of air. The radiator doesn't appear to be blocked but I haven't taken it out, i've only looked at it.
I attached some gauges and i got the following readings: -
Engine turned off both high and low are at 125
with the engine running the readings are 175 and 42 they change very slightly but basically they stay the same.
what's going on? low on refrigerant? too much refrigerant? expansion valve not working correctly? compressor going bad? pressure sensor not working?
I lost my job due to the pandemic so i'm not looking to spend too much but it would be nice to be more comfortable when i'm sat at the traffic lights.
Any help would be appreciated.
