Raynman10
I have been having issues with very slow fill at the pump, lots of kick off, etc. It would take me 10 minutes or more to get gas! I did some research and a few of my mechanic sources all said change the Canister Close Valve (CCV) part #31430 3M000. Ordered one from Amazon $75.00 and installed it today. Headed to the pump and a smooth 18 gallons flowed into my tank!
It is a bit of a pain cuz I had to work in the trunk, the part is right next to the Fuel tank air filter. I did not change the FTAF as my guys tell me not to worry unless it codes.
job is
ull the trunk rug and the Styrofoam cover, expose and remove the metal cover (10x10mm bolts) make sure you have a 1/4" ratchet and both short and long sockets as its a tight fit to get the 2 bolts holding the CCV to the Fuel tank air filter. Simple but PITA to get to the bolts. I stacked the tire area with moving pads to make it a bit more comfortable. If you have a light that can attach and project from overhead that would help. About an hour job. Dealer wanted $300 plus parts.
here's a pix of the part:
job is
