Toddasaurus
REEEEEEEEEEEEEEEE!!!!!
- Feb 18, 2018
- Genesis G70
Selling my parts from my WMI install. This is to be used in conjunction with the JB4 piggyback.
Includes FSB, solenoid, quick install adapter, BM10 nozzle, DO7 nozzle, Devils Own baffled 2.25 gallon race tank w/drain installed, WMI pump, and wiring harness connector for quick disconnect of the pump if needed. Also has all fittings installed on both the tank, pump, solenoid, and quick install adapter; HOWEVER, these need new nylon inserts before use! This will also need new hose, and extra all-purpose wire (black and red) which can all be bought from Burgertuning.com in order to be able to install it.
Features of the tank are that it has baffles, so the drain will continue to have liquid supplied during hard cornering and acceleration. I tested it down to 1/3 full and still had no issues of drawing air in the system. The tank lid and drain fitting are both completely water tight. The lid also has a one-way vent, which allows air in, but not air or liquid out. This is the same concept as BMS's CNC cap for their WMI tank, but this one is much heavier duty. Metal straps are also included with the tank.
Pics...
Asking $250 shipped. ---- Again, remember, you will still need tubing, nylon inserts for the hose fittings, and black and red wire from BMS to complete the kit!
Pics...
