Started and drove 2 genesis at 2 different dealers, both 4.6's. In both instances I turned to the salesman and said, sounds like a lifter problem. Sounded like a sewing machine tapping noise. enough for me to reconsider whether to get it or not.My Genesis has a noticable noise on the cold start. The dealer says Hyundai says this is normal or within range. I dont think so. I purchased the vehicle in January of 2009 the noise was not prominent then. I live in Texas where I can't blame the noise on excessively cold winters. Basically the engine is a bit noisey anyway for the quality of the vehicle.
ADVISE!!
A.Y.
I thought it was just me, i noticed this problem a few months ago and spoke to the service techs at the dealership when i went in for routine maintenance. They said it's normal engine sounds, i said this car is too new and too nice for such sounds. Now the sounds are getting worse, between the engine sounds and my tires sounds i need to turn the radio on loud to drown out all the noise, it's irritating!!!!
What with the windows open?!?! The Genesis is one of the quietest cars I've driven...very well insulated...including the glass.
No with all windows shut, the engine makes the noise on start up and while i'm driving, everytime i press the gas, my tire issue only happened when i changed out my dunlops for my blizzak snow tires. i have an appointment with the dealership on the 30th i'll have them check both issues out
I
3.8 uses solid lifters.....Solid lifters slightly wears out but not much. I have seen solid lifters maintains it's proper gap at close to 200,000 miles. Of course there are also those engines that require gap adjustment at lesser miles. That is why it calls for an 60K inspection on the Maintenance Schedule. Adjustment to these solid lifter engines is a "MAJOR" maintenance as it requires the dis-assembly of the rockers, taking miniscule measurements and replacing worn-out "SHIMS" with the proper thickness to achieve the specified lifter gaps.
