I bought my car recently and noticed that when I turn off the car. the car says there are windows open and the sunroof open but everything is closed. How can I fix this problem.
Should i do a recalibration of the windows or maybe un plug and replug batterie?
Try this first:
To reset the power windows
If the power windows do not operate
normally, the automatic power window
system must be reset as follows:
1. Place the Engine Start/Stop button
to the ON position.
2. Close the window and continue
pulling up on the power window
switch for at least one second.
properly after resetting, have the
system checked by an authorized
retailer of Genesis Branded products.
Automatic reverse
If a window senses any obstacle while
it is closing automatically, it will stop
and lower approximately 12 inches (30
cm) to allow the object to be cleared.
If the window detects the resistance
while the power window switch is
pulled up continuously, the window
will stop upward movement then
lower approximately 1 inch (2.5 cm).
If the power window switch is pulled
up continuously again within 5 seconds
after the window is lowered by
the automatic window reversal feature,
will not operate.
