20" wheel offset
Transit
I have a 2010 Genesis sedan 4.6 looking at some 20" wheels in a 20X9 up front and a 20X 10 in rear. I just don't know what offset to keep the tires flush with fenders. Wheels have a deep outside lip.
Check out Fitment Industries gallery. There are a decent amount of them on there that show specs of rims and pictures. A couple below will probably give you the look you are going for.
Front: 20x9.5
Offset: 45
Backspacing: 7
Stance: Flush
Rear: 20x9.5
Offset: 45
Backspacing: 7
Stance: Flush
Front: 20x10.5
Offset: 32
Backspacing: 7
Stance: HellaFlush
Rear: 20x10.5
Offset: 32
Backspacing: 7
Stance: HellaFlush
We
Front: 20x9.5
Offset: 45
Backspacing: 7
Stance: Flush
Rear: 20x9.5
Offset: 45
Backspacing: 7
Stance: Flush
Front: 20x10.5
Offset: 32
Backspacing: 7
Stance: HellaFlush
Rear: 20x10.5
Offset: 32
Backspacing: 7
Stance: HellaFlush
Thank you for info
Depends on how much time and patience you have to fine tune all your fitment.. what suspenion your going to run. Tiiires.. tire siiize
My info is in my sigIMG_20200919_174917_200.webpIMG_20200318_000002_950.webp20200708_202957.webp20200323_175132.webp20200328_111005.webp20200317_224728.webp20200317_212007.webp20200317_173409.webp20200317_185928.webp20200317_185958.webp
Any fender rub?
Any fender rub?
Depends on my ride height and what im doing with the car. But under normal driving conditions no.. ill rub on a f**ked up driveway or entrance if I'm not paying attention.. but thats more from being lowered not my offseta hahaha
Any fender rub?
I'm looking at the below for my wheel sizing Any obvious issue? 2011 4.6L
Wheelsize: 20
Wheelwidth: 9 & 10.5
Offset: 30 & 35
Brand: Toyo Tires
Model: Extensa HP II
Size: 245/40R20 & 275/35R20
Your rears will poke fore sure. 10mm or so I'd say .. 20x10 + 38 is perfect flush fitment while clearing suspension and brakes.. use that as you base.. and as you adjust tire width make sure to account for the change in Offset to maintain flush..
Use this it will help you a ton
Nice, yea getting coils too, so will have to take that into account.
I'm looking at the below for my wheel sizing. Any obvious issue here? 2011 4.6L
Wheelsize: 20
Offset: 30 & 35
Brand: Toyo Tires
Thanks! I'll check it out
My info is in my sigView attachment 32335View attachment 32336View attachment 32337View attachment 32338View attachment 32339View attachment 32340View attachment 32341View attachment 32342View attachment 32343View attachment 32344
Your fitment is where I want my tires to sit. Your car looks awesome!! I was told to use a 35mm up front with 20X9 and a 40 mm with a 20X10 in rear. I didn't want to touch the suspension unless I really have to. I just want my tires to sit even with fenders. I'm looking at some concave wheels . So would you recommend that tire size. for my staggered fit. 255/35/20?
If you're not planning on lowering the car this is more so what thatd set up would look like.. this was on storm lowering springs that lowered me about 1.5 - 2 inches from oem20190707_185557.webp20190707_185417.webp20190707_185822.webp20190707_185520.webpScreenshot_20190707-212327_Instagram.webpScreenshot_20190707-212320_Instagram.webp
