need help identifien this part
1iwilly
hello my daughter 2009 genesis 3.8 is leaking oil from this sensor located on top of the valve cover there is left side and right side i can't find what is call and is it difficult to change auto parts has no clue as to what it is from looking at pic thanks
Can’t tell from the close up. Probably need a whole engine bay photo so people on the forum can see where it’s located instead of a close up with no other details
Well the moment I posted that joegr posted an answer. What timing
Looks like thermostat
here is an update its call oil seal cap=24570-3C110 and the part under that is call OCV=oil control valve = 243553C100
the Hyundai parts dept finally call me back today with that info
Glad you were able to find the part.
Was this repaired by replacing the part and any seals or gaskets?
did you get to change both or just the seals?
Sorry for bumping an old thread but my 2011 4.6 is also leaking from the oil control valve. I was quoted $1k to repair this which doesn’t make sense to me. Apparently there is some labour involved as the engine cover needs to be taken off but this thread suggest the opposite. So I wonder if you had to replace only the seal cap or also the OVC and how much labour was involved?
