ENGINE START / STOP BUTTON ISSUE
Phiferwt
NAS PAX River, MD
Genesis G80 Ultimate
Here's one. This is an intermittent problem, when I push the start/stop button to shut the car off I get a total power failure (everything, no radio, no seat movement, no lights, nothing). It is like something trips the main circuit breaker, and everything comes back a few minutes later when the breaker cools off. Has anyone ever had this problem? '16 3.8 AWD Ultimate.
Battery terminal failure.
If it happens again, pop the trunk with the key and smack the floor a couple of times over the battery. Bet it comes back to life immediately.
Could it be loose. Everything works fine except the shut down...
Yes, the problem is it probably won't get any tighter no matter how hard you crank the nut (which will break off). If you take the cables off and reinstall you will probably delay the issue for a while.
It's only an issue because the battery doesn't have enough of a connection when the terminal warms up.
Yes. Dealer can’t replicate!
Had the same issue last week shutdown would kill everything and if I turned the steering wheel at low speed everything would go dark and come back on engine keep running turned out to be a loose positive battery terminal
2015 Hyundai Genesis 3.8 Awd tech package
I just experienced the same today. When I depressed the button too turn off the car, everything shut down. I noticed that 'ACC' was lit. I depressed the button again to shut the car down.
Happened again, later in the day. No problem when starting.
did you solve the problem cos i have exact same problem
