V15 Navigation Update available! Here is what's Inside
Canada
Genesis G80
They seem to have changed their delivery methods. Please try the link I just posted.
I'll take a look. Do I have to install on my pc and then to a USB I have to buy? Before, they just sent me a USB and I inserted into nav system.
Does your car have an SD card? If so, take the existing SD card out of the car and put it into your PC. Then download the update directly to the SD Card. Then put the SD card back into the car, and start the engine. The update will start automatically. It took about 20 minutes on mine.
Thanks, usb. I'll just wait. Site indicated update available mid April
Just did the update. It actually has my street now and can get me home.
Biggest change I noticed was the menu when I push the controller. It pops up a menu with Home, Work, last 2 destinations, then the other options. Home is not two taps away.
Could not rearrange the radio stations though.
Took update for 2015 Ultimate. Went smoothly. Has anyone else noticed a stutter at the end of text messages "listened" to since the last couple updates? I didn't get the copper/old Genesis colors...
On your 2015 Ultimate, did you only need to update the SD card? Past updates required ordering the usb stick with the new SD card.
No. I did need/use USB last time but not this time. Download to laptop took 30-45 mins. 20-30 mins to load to SD card (32g) 20+ mins to load to car.
I hope they've greatly improved the map coverage. I tried to use it the other day to navigate to an address outside of Boston and it didn't have it. These weren't exactly new roads.
I always have to use Google maps instead. So far I've yet to use the car's navigation because it either doesn't have the destination or it sends me the wrong way on some crazy route.
There is a pretty good map update/edit feature on mapnsoft
Thanks. Is that different from the version update that's being discussed?
Different website. Mapnsoft.com. The updates are coming through a new Hyundai/Genesis map update app.
Bummer about the radio stations. I was really hoping they were going to fix that issue.
So, I did the update on Monday and the procedure was the same as previous updates. It appears I have a new look and functions but since the update completed I'm presented with the "Okay to Update" prompt when I start the car (sometimes). If I elect to cancel the Update everything works fine, if I select "Ok" it proceeds to re-do the update, completes and reboots then asks again if I want to do the update. Going to order the SD Card when it becomes available and try inserting that.
