instrument cluster
ickcruz
south jersey
Can you please show how to remove the instrument cluster on 2011 sedan?
2011 Hyundai Genesis 3.8 V6 - 3.8L 3778cc 231ci GAS MFI vin E - 4 valve DOHC
Hyundai
2010-11 Genesis
Instrument Panel
Refer to Fig. 1 when performing replacement procedure.
  1. Remove lefthand and righthand instrument panel side covers.
  2. Remove mounting screws and lower panel.
  3. Remove mounting screws and cluster fascia panel.
  4. Remove mounting screws and cluster.
  5. Remove righthand instrument panel side garnish mounting screws and garnish.
  6. Remove center fascia panel mounting screws and panel.
  7. Remove mounting bolts and reinforcing panel.
  8. Remove audio assembly mounting screws and audio assembly.
  9. Remove mounting screws and audio head unit.
  10. Disconnect damper from glove compartment.
  11. Remove mounting screws and glove compartment assembly.
  12. Remove steering column shroud assembly.
  13. Remove front seat mounting bolts and front seats.
  14. Remove lefthand and righthand A-Pillar trim panels.
  15. Remove instrument panel lower panel.
  16. Disconnect passenger air bag connector.
  17. Remove bolts and nuts and instrument panel, Fig. 2 .
  18. Remove photo sensor, Fig. 3 .
  19. Remove rain sensor connector, Fig. 4 .
  20. Reverse procedure to install. Torque air bag module mounting bolts to 72 inch lbs.
Copyright (C) 2020
Thanks for your quick response a guy further down the forum said he was able to do in a 15 minutes, do I really have to unscrew all that just to get to my dashboard to take my instrument cluster out
Not sure, this is the procedure listed in the manual. I have never done this particular job so i cant speak from experience. I can say to use caution when removing the trim around the radio, it is very delicate and cracks easily. I would say that if there is someone who has posted about this job and how long it might take, to message them and consult directly.
Thanks for your reply... Yeah there was a guy who posted it and he switched his instrument clusters out but he has been on here since 2017 lol
Hi any chance you found somebody to tell you how to remove it ? I need to do the same on my 2009 genesis 4.6 to replace check engine light bulb
curious, was it a bulb or an led??
