inmanlanier
- Jun 9, 2011
- Location
- Palm Beach Gardens, FL
I have a 2015 Genesis 5.0 sedan. After changing my oil again today and cursing at the challenge to remove the black polymer oil filter housing, I've done several searches to try and locate the correct tool. I have numerous oil filter housing removal tools, however none this large. Unfortunately the car is back together now so I can't try and measure.
In searching the internet, I found one suggestion of 88.5mm with a ? after it. I searched and found an 88 mm tool on Amazon that states it's for Hyundai, but it is 15 flutes. https://www.amazon.com/dp/B00KMUMKWE/ref=pe_825000_114212990_TE_FOCE_n_id
The photo in another post for the 5.0 shows a photo and it appears to be 12 flutes. Oil filter housing ratchet size? There's a 76 mm, 12 flute on Amazon for BMWs https://www.amazon.com/KiWAV-Filter-Wrench-Removal-flutes/dp/B00IZGDV6G Someone in a different post commented that there were alot of similarities between BMW and these cars due to some engineers that moved over to Hyundai from BMW.
Using the 5.0 filter/housing photo above and scaling, I come up with very close to the 76mm size as mentioned that's used for the BMW filters.
Does anyone know the correct tool size (including correct number of flutes)?
