JasTheAce
I have a 2015 Genesis 5.0 NOT ultimate. Current mileage: 37600, bought new (demo) with 5000 miles on it. Aside from maintenance, I have had zero issues until this summer.
In mid-June, I noticed I started to have a couple of strange issues when turning the car off. Occasionally I would hear a loud popping noise, see the analog clock reset to 0, or the trip odometers reset to 0 miles. I had issues with the left turn signal bulb (also DRL) burning out a couple of weeks before, which I had not thought anything of. At the end of June, the turn signal blew out again, so I took it to the dealership for them to change it and to look at the strange electrical issues on 6/29. They said there was no issues at all.
Incident #1:
3 days later on 7/2, the whole electrical system of the car shut down during the start sequence (pushed the button, steering unlocked, and the whole car shut off - zero power) on the first start after running a morning errand. It had to be towed to the dealership because it wouldn't start. Upon arrival at the dealership it was in the 'on' mode, started fine, but was having difficulty staying running. Dealer found a short in the fuel pump which prevented it from operating normally (no issues prior to this) and replaced the part. Car returned on 7/6. Driving out of the lot, noted the other blinker had failed. Called to bring it back on Saturday. Replaced bulb at dealer.
Incident #2:
2 days later on 7/8 the popping noise occurred again and trip odometer was reset. Took it back to the dealer on 7/9 where a junction box was replaced which had a short in it. Car returned on 7/13.
Incident #3:
6 days later on 7/19, the whole electrical system of the car shut down again (same symptoms as #1) during a cold morning start. Towed to the dealership, and once again was 'on'. Dealer looked at the battery terminals and determined one of the posts wasn't tightening fully and was freewheeling. Terminal post replaced/repaired. Car returned on 7/25.
Here's my issue - based on my experience with computers and electronics, losing power wouldn't cause components to short out, but would just stop them from working. Furthermore, if the battery was disconnecting, I would have much different issues and wouldn't have power to lock doors, wait overnight, and unlock doors in the morning. I don't think the issue has been solved, and I've escalated it to corporate. Not sure what to do at this point, but I'm really wanting to make sure I've looked at everything it could possibly be. I'm terrified that the car is going to leave me stranded somewhere, and it's bad enough that I didn't even bother putting the shift lock plug back in after the second tow. Furthermore, I'm not sure how comfortable I would be selling the car to someone (i.e. Carmax, dealer, or private) knowing that the electrical issues could strike them as well.
Any advice/thoughts/expertise is welcome.
Thanks!
Incident #1:
Incident #2:
Incident #3:
Thanks!
