Secret Menu? Dealer Menu key combo?
EndersGame
Harpers Ferry, WV
Most cars have "dealer menu" or debug menu's or "secret" menu's if you want to call them that.. for instance on the chrysler 300c you would press down the bottom buttons on the left and right parts of the steering wheel and it would display the additional menu options on the console, allowing you see many extra sensors and menus, like a digital speedo as well.
I was wondering if anyone has found the Genesis menu?
Interested in hearing info on this. :)
Dan
There is a service menu or "engineering menu" that can be accessed. I think I saw it on a thread here but I just don't remember where. Search on update or engineering and you may find it. I tried it to see what was available. Nothing too exciting in there IMO. You can change a few things but nothing earth shattereing if I remember correctly. You can also see what versions of software you are running.
I had this stored in a file(which I got from here I believe)
Try this:
Press info/phone
Press again to enter phone menu
Select phonebook - new entry
Select " 1@ " then OK
Enter " ##0324#0704## " Then OK
After I select "1@", the OK button still is gray out. I cannot put the OK button. :(
I get the same thing, just enter the rest of the code and continue ........
Secret or dealer menus can be fascinating because they unlock hidden settings that aren’t always visible to regular users, but they should be approached with caution since altering the wrong option could affect performance or even void a warranty. It’s always smart to gather guidance from dealers or trusted forums before experimenting, and to document any changes you make for safety. Just like checking innoutmenus before ordering to be sure of your choice, doing research first ensures you get the benefits without unexpected problems.
