Spark plugs for Genesis G80 3.3 T??
hwhorf
Genesis G80 Sport
Hey
What are some good performance sparks for Genesis G80 3.3T Sport. I am going to try out the Racechip GTS and I think I need to change out the sparks. Will these ones work? It says it's for the Stinger/G70 and G80 T-GDi is a different engine.
Denso 5346 IKH24
Will any of the NGK sparks work?
Thanks!
Hey
Denso 5346 IKH24
Thanks!
Yes those spark plugs will work just fine. Those are the ones I’m currently using with my JB4 haven’t had any issues. Stock plugs like NGK should also work if gapped to .022 but will not last as long depending on how aggressive you’re planning on going.
Apparently you get better fuel economy so I plan on driving reasonably
Should I go with the 'step 1' or 'step2?'
On tuned 3.3's, the NGK M45iL has been proven to last longer than the lessor expensive Denso plugs, FYI
Yes correct. A little more pricey but have also heard they have better heat resistance than denso plugs.
Step 1 should be all you need. Step 2 is for more aggressive tunes if you’re planning on pushing your engine to the limit.
Can you recommend a website that carries these plugs.......... My google search keeps turning up HKS plugs...............
Thanks. Are HKS, similar in quality and performance as NGK?
I would say these are a little better than the NGK plugs that’s why they are pricier but if you’re not running anything super aggressive the NGK plugs will be just fine. I have been using the step 1 denso plugs for 6k miles running map 4 constantly and have had no issues. I’ll leave the link to those as well.
