Ggpe
- Jul 12, 2021
- Genesis Model Year
- 2019
- Genesis G70
I took a light out n found the panel strips above the front doors are glass also! The rear half of top is not. Obviously, half of the is glass n half is not! My only question now is one I need answered by Genesis and has nothing to do with engineering.Are you sure ?
The back panel in my G80 (not G70 though) is glass.
I would think glass was chosen for a reason. A piece of sheet metal may not be easier or more cost effective to install. A piece of sheet metal may also be more difficult to break in (remove) for repair of what lies behind. Bit far fetched, still a possibility.
Glass will also be a better sound attenuator. To achieve this a sheet of metal needs to have some sound deadening material sprayed or glued to it. Otherwise during rain or hail it will ring like a drum.
On closer examination, (on my vehicle) I can see a small part of the panel's underside is screen printed and the rest is clear and reveals black painted matte metal a short distance below.
From this I deduce the following:
1) The small part which is screenprinted hides, most likely, the roof mechanism. And everything mechanical needs access for servicing/repair. I am sure glass is easier to remove by just breaking it and remove fragments from the edges with special solvents. I know this from the building industry. But, this is only an assumption on my behalf.
2) The matte painted steel I can see through the “not printed„ sections of the glass is the stiffening brace to stop cabin flex. (As is the middle section of the roof.)
Why is this glass panel not painted black all the way on the underside I hear you say ?
Glass, and particularly toughened glass, does not play nicely when this is the case. Heat buildup will be enormous, expansion also and in case of tight fitment requirements to stop leakage this would not be good.
I have, I think, exhausted all possibilities and leave it at that.
This site had been very helpful and insightful!
