LAP3 ECU and TCU Review
Cashby
All I can say is “holly shit”. Why didn’t I do an ECU tune from the start? Just received my LAP3 stage 2.5 ECU and Stage 3 TCU. It is seriously a night and day different car now and I am beyond impressed with these tunes.
Up until recent, I was running JB4 with Charge Pipe Injection and bolt ons. JB4 has served me well and I will continue to use it for my charge pipe injection as well as fine tuning AFR/wastegates if needed down the line. With JB4 I made 471whp and 510wtq and would run consistent mid/high 11 second ¼ mile passes and 3.6-.3.7 0-60’s. Simply put, JB4 is great but I quickly learned how much more a proper ECU tune can do.
After doing a ton of research, talking to multiple Stinger/G70 guys with different ECU tunes, I went with LAP3. There are several reason why I went with them. The biggest reason being communication. David at LAP3 answered every single one of my questions in absolute detail. He would then go into explaining how/why their ECU/TCU are tuned liked they are. They are a phone call away and very quick to reply. I hit up several companies to ask questions. 2 of which I never even received responses from after multiple attempts. After my research, I am glad I didn’t go with them as multiple people were having issues with their tunes and had to keep sending it back for revisions.
LAP3 Stage 2.5 ECU review: (plug and play right off the shelf)
ADAPTATION:
  • I was very surprised to see how quickly the ECU adapted. It does adapt based on the fuel/octane content that you are running, and it adapts quickly. More octane nets more timing etc. I run E40-E45 which will lean out AFR however I was surprised to see how spot on my fuel trims and my AFRs were after very small amount of driving.
BOOST:
  • There is almost no boost taper with this tune. The tune itself runs lower boost (18-19lbs) but it hold all the way to redline in every gear. I do not get any boost spikes when shifting gears and it is very consistent. I did a lot of research and after seeing people with other ECU tunes with some crazy boost spikes, or boost taper, etc. I didn’t want to take the chance grenading turbos/motor with massive boost spikes. A lot of people are hung up on running more boost, but it isn’t key to making more power or running faster times. LAP3 2.5 ECU has lower boost with a very consistent powerband.
TIMING:
  • This was the absolute game changer. With JB4 I would get a max of about 15 degrees towards redline. Being that JB4 can’t control timing and the OEM ECU is limited, adding more timing made a huge difference with LAP3. However, adding more timing comes with adding more octane or WMI. The LAP3 ECU will adjust and add more timing based on octane being used. I run E40ish with no water/methanol and I am hitting a max of 20 degrees of timing. The good part is it’s throughout the power band and not just at redline. This alone made the car feel like an absolute monster and a lot of power was gained. (more to come on fuel/timing)
FUEL/WMI/E85:
  • After speaking with David at LAP3, we had our concerns with me running the Stage 2.5 ECU without having WMI or running race gas. I run BMS Charge Pipe Injection which allows me to run more ethanol content and not crash the HPFP. No one has tried to run the LAP3 Stage 2.5 ECU without WMI/E30 blend, so I figured I would be the Guinea pig. Well, safe to say that the tune runs flawless with no issues on a E40-E45 blend. Going back to adapting and timing, Plugged the ECU in and went for a drive. I had the standard adaptive timing corrections which were about 2 degrees in every cylinder. Much to my surprised after a little driving, the ECU adapted and I get 0 to 1 degree of timing correction now. This is with having 20 degrees of timing throughout the power band. So, the ECU runs a lot more timing but it does hold up and run safe with a E40+ blend. Needless to say we were both happy and hopefully opens up more options for people wanting to run LAP3 ECU tune without running WMI or race gas constantly.
CONSISTENCY:
  • Made this a topic because I feel like the car is sooooo much more consistent. I have done back to back pulls, logs, ¼ mile times etc and the car just performs spot on every single time. Today was 90 degrees out and the car still ran like a champ having higher IAT’s. Now we all know that weather/driving conditions etc. will change how the car acts. That is what is great about this ECU tune. Again, it adapts based on all these much like the OEM ECU making things safer and having much more drivability that is consistent every time.
OFF THE SHELF: Plug and play
  • Received the ECU in the mail, plugged it into the car and drove. There isn’t a single thing that I would change about it nor does it need to change. (aka revisions). I know ECU tunes that are available offer “revisions” for X amount of dollars or X amount of time after purchasing. Sure, this makes sense down the line if going to a bigger turbo set up or something much more aggressive. Of course you are going to need a revised tune. I am more talking about the 99.9% of us who just have bolt ons. I have had several people tell me they had to ship their ECU back and forth to the company they got their tune from just to make it run properly with their full bolt on setup. The LAP3 ECU tune doesn’t need any revisions. It is legit just plug and play and done right the first time around.
  • No more ISG for Stinger guys. They now have the ISG delete with their ECU tune. No need to wait for “beast mode” or launch control because of ISG. (idle stop and go)
LAP3 Stage 3 TCU review:
  • Coming from a LOZIC stage 3 TCU, I was curious how much different the LAP3 would be. The main reason I went with the LAP3 TCU was solely to pair it with their ECU. Right off the bat, the biggest difference I noticed were the downshifts. When I had LOZIC, the 2nd to 1st gear down shift was sooo harsh and would take me by surprise every single time because of how abrupt it was.
  • Launch control is a lot more consistent. Doesn’t have to be in stages and builds boost a lot faster (much like brake snip).
  • Shifts are firm and quick. I went with stage 3 which might be a bit more aggressive for some but I love how fast/hard it shifts. I will increase your 0-60 and 1/4 mile times.
Ok, you just read a lot. What did all of this net me in terms of “gains”. Well, with full interior (no weight reduction), spare tire in, golf clubs in trunk, full tank of gas and on 20-inch 68lb wheels the car ran 11.3@ 120 MPH and 3.2 0-60 less than 24hrs after installing the tunes. This was with a not so great 60ft at 1.7x. With my track wheels/tires alone and cutting 1.6 60ft I see no problem hitting 11.0-11.1. Then maybe if I take all the crap out of my car (spare tire, golf clubs, seats) ill save another 100-200lbs . I have no doubt that it will break into the 10’s and get a faster 0-60. All without race gas or WMI.
My current mods:
LAP3 stage 2.5 ECU, LAP3 stage 3 TCU , JB4 with BMS Charge Pipe Injection, Fuel-it flex fuel sensor, BMS FMIC, BMS catch can, BMS intakes, SXTH Element High Flow Cat primary downpipes, DC catless secondary downpipes, Muffler delete with vibrant resonators, stock mid pipes, VT Snorkels, BMS trans cooler, BMS rear diff brace, BMS Billet strut bars, HKS plugs, 20" Niche Gammas, Eibach springs.
Some draggy times so far. I banged the rev limiter in 1st gear slowing it down a bit. I will update this thread as I continue to go faster.
I saw your post on Stinger's forum. What's the cost of LAP3's ECU/TCU vs. Lozic's ECU/TCU?
I wonder if LAP3 are capable of tuning G80 sport the same way as they do G70?
Nice, Cashby! That's a 10 second car on a track with some weight loss!
Im thinking the same my dude! Today I am going to at least take the spare tire out and golf clubs out. Thats 100lbs right there. I want to see how fast it is as a daily driver with no prepping done.
At the track, full prepped, a lot less gas, weight reduction etc, It will break 10's.
These alone will help with that ;) Some lightweight 18's with sticky tires I picked up
Update for today. Just need a lower 60ft and we will be in business. (spare and clubs still in)
Nooiiiccee. Thank you for the review. Have been patiently waiting for it. When you post some more videos, let us know!
Will do!
You come from Audi/VW background? I had Maestro on my stroked big turbo A4.
Curious to find out how much just the ECU/TCU tune work with 93/91 pump gas. Stage 2.5 doesn't seem to be made for that, but if you ever get the opportunity that's cleared with your rep at Lap3 let us know!
Someone today ran 11.5 with just ECU/TCU and 93 octane. no other mods. stock exhaust and all.
The ECU is much like the OEM ECU and will adapt based on the fuel you are running.
Will do!
Nah. Always liked that word so used it from there. I'm more from the BMW side of house. That is why I am so interested in improving the G70. Particularly in the TCU. Any experience with the newer ZF units? Would you say the TCU tune gets to those speed/responsiveness levels? Noticed the G70 likes to deny me a downshift here in there even when within gearing ratios and no chance of over revving/protections.
My current mods:
That's a lot of modifications! Is the car still reliable like that? looking into buying one as my daily and modding it in a similar way.
Also, do you have a youtube channel, or videos of the car?
Very reliable. Its just full "bolt ons". All of which helps with power and fuel economy (if you don't have a led foot)
The trans cooler, diff mount, intercooler and strut bars help even more with longevity and consistency.
nice! is there any way i can DM you if i have any more questions?
It is algorithm driven. 10, 12, 15, maybe 20 with no complaints is sufficient but one cannot predict. Any post will suffice, so far as I know. Make a few comments or questions and you will be there.
Lucky me, I have plenty of questions to ask!
