Voltage drops from 14.5 to 13.8
daniel.atcheson
Help!! I have 4.6 09 sedan. Why after 5-10 min does my battery turn on. Therefore, disabling useful things such as my rear window defroster and heated seats (I reside in MN, these things are necessary!!). Is this a bad relay or fuse? Is it the one on the connection at the battery. There are two types of fuses located here. I can test one and have replaced the other. Still nothing changed this. Also have replaced both battery and alternator this current year. Ideas?
Welcome. Moving this discussion to the proper section...
What does this mean? Are you saying after 5-10 min your alternator is no longer working? Because your battery only works during the initial start up, than you alternator takes over.
Have you tested your alternator and battery (also load tested)?
Help!! I have 4.6 09 sedan. Why after 5-10 min running, does my battery light turn on and voltage reduce from 14.6 to 13.8?? Therefore, disabling useful things such as my rear window defroster and heated seats (I reside in MN, these things are necessary!!). Is this a bad relay or fuse? Is it at the battery? There are two types of fuses located there. I can test one and have replaced the other. Still nothing changed . Also have replaced both battery and alternator this current year. Ideas?
I
Corrected my grammatical mistakes.
Thanks!
Red dashboard battery light is 99.9% of the time a bad alternator or bad voltage regulator (i.e. also bad alternator).
Test your alternator and battery.
Most auto parts stores can test your charging system on the vehicle very easily and usually free. Most alternators have the voltage regulator built in so if any charge issue are seen, just get a new alternator. OEMs are really expensive and plenty of after market alternators are available with decent warranties. I had a warranty issue with a Rock Auto alternator for a Civic and they did a warranty exchange for me very easy.
