sherrod
I'm trying to better understand the operation of the Electronic Stability Control (ESC) system. I know that its basic function is to perform throttle control and differential braking to keep the car from sliding, but I don't understand the details.
I have seen a number of messages in this forum where Genesis owners complain about ESC being a "nanny" that won't let them drive the way they want. I guess I'm not as aggressive a driver as others, but I've never had ESC engage during normal operations.
Once I decided to test ESC, so on a rainy day I floored it while turning sharp right from a stop. The white ESC light on the instrument panel flashed on, and apparently the throttle was reduced, because I didn't hear any tire squeal. But other than not having any skidding, I didn't notice any effect on the handling of the car. If I hadn't been looking for the ESC light, I wouldn't have known it engaged. Its actions certainly weren’t something I would complain about.
I believe ESC is triggered by two things:
1. It detects drive wheel skidding and reduces the power to stop it.
2. Gyroscopic sensors detect the car is spinning (i.e., rate of turn is greater than expected for steering wheel angle), and differential braking is applied to correct for the spin. I don't know if the throttle is also reduced in this situation.
Am I correct about the triggering events and resulting actions?
Under what situations have you found ESC problematic?
