mch4424
- Sep 30, 2021
- Genesis Model Year
- 2011
I have a 2011 Hyundai Genesis, 107k miles. Not one single issue so far with this vehicle until now. I'm struggling to drive to work because of the freezing temperatures and no heat in my car. Just working on it is giving me hypothermia.
Problem: A/C Blower motor does not turn on with any speed or setting.
What I've tried:
I have changed the **40a fuse** for the blower motor.
I have changed the **blower motor relay** in the fuse box.
I have put a brand new **blower motor** in the vehicle.
I have installed a new **blower motor resistor** in as well.
Nothing has worked so far. Blower motor randomly worked one day, and now for the last 2 weeks I've had nothing at all. I pulled the fan out, hooked up to a spare 12v battery, works perfectly. I started my vehicle, hooked up a volt meter to the leads and (got 14 volts coming from the connector itself.) However, when the connector is plugged into the fan, no response from the fan at all. I thought it might be a bad connector, so I jumped cables from the connector to the blower motor and still nothing.
I am out of ideas at this point and I've never dealt with grounding issues before or anything. I asked my mechanic buddy and he thinks it could be a head unit issue (however the head unit can change the vents fine and everything else functions perfectly except the blower motor.) I would greatly appreciate any advice.
What I've tried:
