2016 Genesis license plate light
Lorijean
Hi
Is the light LED or regular bulb?
Pretty sure it's led
do a quick search for the trunk harness fix your harness in your trunk might have snapped
I peeked under the felt and the left light was unplugged. How THAT happened I do not know but when plugged back in it flickered. The more the wire is pushed into the light, the light comes on. As far as the right side I’m still not sure I guess until I take it all apart.
It is. Sadly It seems almost impossible to replace.
the whole set up is back there is bad design in my opinion.
the harness is ran tightly up the rightside trunk hinge, every time you open and close your trunk it stretches and snaps the wire (in my case). It seems like its pulling ur connector out. Its a easy fix the longest part is getting the carpeting out of the way. You remove a bracket and fix any damaged wires.
