My friend asked me to figure out a solution for his 2013 Coupe R spec that simulates pushing and holding the ESC button for 3 seconds upon start up. I believe he wants to take it to the track and have fun without nannies kicking in. I found a 528T Pulse Timer that can be programmed to do this, that way the driver doesn't need to manually press and hold it every time they start the car. I also took it a step further and added a toggle switch to enable/disable the timer from activating. Finally, I am adding in a diode on the output of stock ESC button and timer so that the stock ESC button can manually enable/disable ESC as originally intended anytime during normal operation and power doesnt flow backwards. According to my friend, once he held the button for 3 seconds, it completely disables the ESC from kicking in. I plan to visit in May so I can let yall know if it is successful or not. If anyone has other inputs that may help in the meantime, I'm all ears.
