Need your help again !
junhon
Hi guys again!
I really appreciate for the advices on the HID question :)
I need your help again.
I am about to replace the licence plate bulb to LED bulb.
I took all the screws and tried to take the plasctic cover out, but it did not
work. The plastic cover is a little bit bigger than the hole.
Do I have to remove the black cover attached on the trunk first ?
Can't wait uploading pictures here with HID and LED at the back !!! :) :)
I removed mine last weekend. Once you remove the screws, you have to angle the light downwards and its should pull out. If it feels a little tight, its because the wiring is tucked away in the back. What bulb are you using?
DubaiRich, Thanks!
What I was doing was right..but, it sounds hard! :)
I will try it again! I got the 37mm 6 LED bulbs. what about yours?
I haven't purchased my bulbs yet, but it's one of the many mods pending.
Same here. :)
Let us know where you get the bulbs from.
Dan
I have changed both trunk lights, plate, glove box and the underside of the door.
By far the hardest was the plate lamps. They were hard to get out so stay at it.
All lamps were purchased at superbrightleds.com
