Auto Hold - Creeping Forward
SixFootSix
California
I’ve noticed that my 2016 3.8L Auto-Hold has begun to creep forward ever so slightly while stopped at a light or in traffic.
I can hear the sound of the disc brakes on the rotor, similar to when the rotors get wet.
Is there an adjustment or way to activate the Auto-Hold a bit stronger?
I will need to check if the pads are simply worn down and need replacement to resolve the auto-hold creep.
That would be my first step. Don't know of any adjustment, never had it happen.
The harder you press the brake pedal, the higher the pressure that the auto-hold will keep on the brakes.
Well that could certainly explain the slight creek forward. I’m much harder on the skinny right pedal than the left rectangle pedal.
I will give that a try and see if it helps.
I rotated my tires today and checked both the front and rear brake pads. The front left pads are very low. The front right have almost twice the material. The rotors are smooth and without any grooves. I will schedule a front brake pad job next month.
