Nav update gone wrong
john mortimer
So I recently purchased a 2019 g70 and love it. The nav needed updating and so I downloaded the updater and loaded the update onto a 32 gig thumb drive. Now I'm getting a "nav not available, check SD card" message. The update also changed the look of the entire gui, not sure if I like it but that's not really an issue.
Should it have been downloaded to the SD card? Don't know about yours, but on many other models you use the SD, not a thumb drive.
Yeah, the directions on the updater were not clear on this point; it indicated both are OK in one spot but specifically mentioned only the SD card in another. So I'm thinking one option would be to update again via an SD card.
You use the SD card to do the update
Yes. In fact, the folder inside the ZIP file that you copy over to the USB thumb drive is titled "DAUDIO". I just did the upgrade for my non-NAV infotainment.
I received the same error after starting with the SD card inserted. Going through the setup menus as described in the instructions completed the update.
GUI is now different and I have lost my radio presets. Not sure if I did something wrong or if this is part of the map update.
