Crank Shaft positioning sensor
JohnRyanG80_50
Genesis G80
Hi guys,
Apologies in advance if this question has already been asked. I’m trying to replace thr crank sensor for on my 2015 5.0. Does anyone have any information on where I can find the sensor on the car? Any sort of diagram would greatly help.
Thank you guys.
It is located under the driver side valve cover near the firewall on the bellhousing. Number (6) in diagram
You can actually see the crank sensor under the camshaft sensor(A) on the bell housing in this pic.
Here is the crank sensor on my 5.0 engine.
Thank you guys! I appreciate it very much.
This is under the car correct?
Is this the 5.0 or 3.8?
It is a 2015 5.0 Genesis model. The pic is looking down from the engine bay from up top. I believe you will have reach down remove the crank sensor from above. However, it could also be reach from the bottom maybe. I did not remove my crank sensor; only my camshaft sensors.
I have a 2015 also. That’s gonna be pain in the ass to take off lol. Thank you man.
No problem. I probably should replace my crank sensor as well while I got the chance since it does require removing a lot of crap to get to it.
