thatjawncrazy
- Apr 17, 2020
- Location
- Baltimore
- Genesis G70
WRITEUP
New ARK secondaries/secondary downpipes and resonated muffler delete installed. Maybe the best ~$700 I’ve spent besides wheels. As usual…here’s the writeup…
I was honestly getting bored of a fast-looking car with almost zero sound. The turbo noise was nice but it just didn’t sound like ANYTHING. So i fixed it.
You will not have a good time with just a muffler delete. Even resonated, the downpipes really take the edge off. In terms of GOOD sound for your money - i like them better than some of these full G70 exhausts.
Only at 2K under load it sounds like a VQ engine…everywhere else it’s awesome. You hear way more engine inside the car, but you won’t hate yourself like you would with just a muffler delete. And for an engine that sucks at sounding good, it sounds good with these. If you’re the one that hates the stock exhaust and hates aftermarket exhausts…you’ll like this setup.
It will burble the entire time from ~30 mph in sport mode after letting off the gas, and has a really nice edge to it when you accelerate. Slowing down and pulling up to a restaurant with all the burbles is pretty cool.
I can still hear music perfectly fine. Have done many road trips since install. You ain’t sacrificing much. I strongly assume the IMR secondaries will sound similar and install similar to these.
INSTALL
You’re gonna need a normal set of tools, plus about a 12 inch 1/2” extension. And an impact wrench.
You have to take out the two studs from the primary-to-secondary downpipe connection, and the two nuts/bolts from the secondary-to-midpipe connection.
The primary studs are basically impossible to reach without that extension. Just be careful with them. I broke one of them when using my impact to get em out (i drive in snow and they definitely rusted). Everything else is pretty straightforward, only four bolts per side.
Keep track of what gaskets go where. The downpipes should come with their own gaskets.
And, when you put the primary studs back on, tighten them, warm the engine up, then tighten them AGAIN. I did the job when the engine was cold - when it warmed up, some parts expanded from the heat and one stud got loose. Don’t be afraid when you tighten them lol.
SOUND VIDEOS
I'm about to slap my gopro on my rear bumper and go drive around. Stay tuned.
