Aftermarket Wheels Photo
Critter210
Ann Arbor, Michigan
Genesis GV70
Greetings,
I'm looking to install a new set of wheels on my 2022 GV70. I just need to see a set of wheels on a GV70. Please post a few photos to help me decide. Thank-you😊
Here's a photo of my GV70 with stock wheels.
Best Regards,
Nick
Here are some I've found online...maybe more extreme examples 1672775698690.webp1672775633446.webp
I tried editing some of my own as well. Doesn't look amazing, but it gives me a feel for what these wheels might look like. I'm looking for 19" wheels for summer - to try and keep the comfort and ride as good as possible.
These are on my vehicle
Looks great on the silver. What are the specs?
These are my winters.
I don't have picture of the wheels on the GV70, but I saw these wheels on a GV70 when visiting another state and really loved how they looked. These are the wheels I plan to purchase for my winter wheels next season.
one other set of wheels for consideration. Vossen brand
I thought about getting Niche wheels but I was iffy about putting no-names on my expensive vehicle so I got Königs. Niche are reviewed very well, though.
Understandable. I have 22" Niche on my Explorer. After 9 years they still look very good and I've had no issue with them.
I had Niche Milan installed on my brand new 2013 Santa FE XL/LWB. They were fantastic, never an issue. Finish held up well. Would not hesitate buying Niche again. In fact, looked closely for my GV, but just could not find the one I liked that was the right size and also had the right offset. Thus why I went custom.
Greetings,
Best Regards,
Nick
I have a GV70 2022 and am looking for wheels come spring. Been researching alot around fitment to eliminate any issues in that area. Of importance to me is offset, weight, and center bore relative the GV70's hub. Do most consider these parameters or do most just trust TireRack to provide the correct fitment? The GV70 has as offset range of 37 - 41mm range on an 19 x 8in wheel, which I may just stay with if I don't go to a 20in rim. As I understand it, center rings will make offsets less of an issue, or is it center rings are more for the center bore/hub fitment? How many of you have required center rings with your wheel upgrades, and is there any negative effects?
Hub centric rings (center rings) don’t have any effect on offset. They just make the wheel fit on the hub correctly/centered but they are not load bearing; that’s what the wheel bolts are there for. The wheels I bought are 73.1 so I used centering rings to step them down to 67.1. No issues. Get the plastic rings and not the metal ones so they won’t get stuck in the wheels.
You have to look at all that and much more, and it is not always straight forward in calculating appropriate offset, especially if you are trying to achieve a set up as flush with the fender as possible, and without having any poke (ie...when the wheel or tire sticks out slightly from the body). By the sounds of it, you need to do a bit more research and and gain more knowledge if you plan to figure this out yourself. There are a few threads where some have gone into detail, including me, on fitment considerations. Just a few quick notes:
  • Centre rings have zero to do with offset. Hub centric wheels means the hole in the middle is the exact size of the hub flange on your vehicle, so it fits snug and is perfectly centered to eliminate vibration. Hyundai, Kia, Genesis centre bore is 67.1 (same as Mazda actually). Unless you go higher end wheel where the wheel hub is machined custom to your vehicle, then aftermarket wheels are likely to have a larger bore in the 73.something range to make the fitment more flexible with various vehicles. There are some cheaper brands that do make hub centric wheels, but I would be inclined to stay away from those. A set of hubcentric rings is $20 at most, and strongly advisable. These centre bore sizes are pretty standard and you can easily find them with inside and outside diameter to fill the gap of any wheel. Their main purpose is to keep the wheel absolutely centered on the hub when the lug nuts/bolts are tightened so there is no vibration. After the bolts are tightened, they play no role.
  • OEM offset is ET 43 for 21 x 9 wheel with a 255/40/21 tire, ET 39 for the 19 x 8 wheel with a 235/55/19 tire.
  • When considering offset, you need to take the wheel offset into account, wheel width, and tire section width (eg, if you are going with a wider tire that has a section width wider than the overall wheel, then it is the tire that is used to determine "how close to flush with fender" you will be). Also note that wheel width is the inside of the lip to inside of the lip...ie. where the tire beads sit. Some go with a wider wheel and the tire is narrower so it has a stretch.
  • To calc offset, start with stock positioning and change parameters of tire width, wheel width, and offset. Some or all of these may come into play depending on widths, as per my comment above re: tire vs wheel width.
  • Most go fairly safe if going with a 9" wide wheel @ ET+35 (in fact, most aftermarket wheels will offer this offset). That pushes the wheel out for a more aggressive stance, but not necessarily flush.
  • Higher end wheels will custom machine the hub to desired offset. Others offer one or two offset choices in the wheel configuration that fits your vehicle. If you can settle for whatever is offered and not stuck on achieving flush, then your options for aftermarket wheels will be greater.
I just purchased 21" aftermarket wheels for summer that were custom fitted for my GV (ie. their hub machined to my desired and their recommended offset for flush (ie ET 32 as well as the centre bore drilled to 67.1 so no hub centric rings are required). I'll be going with a slightly wider tire (265/40/21 rather than stock 255/40/21), so my tire's section width is actually a bit wider than my wheel, so that is what factored into my calcs for offset.
Could you give measurements for a 22 inch wheels? Thank
Measurements? You have obviously put ZERO effort in trying to understand or even read the posts. 1st post, you have contributed nothing, and you're looking to be spoon fed...not going to be me.
HRE FlowForm FF11
Silver (Liquid Metal) 21x9.5 35
Michelin
Pilot Sport A/S 4
275/35R21
Greetings,
Best Regards,
N
Greetings,
Best Regards,
Nick
Here's a pic with the new wheels
