koovoodoo
- Dec 26, 2022
- Genesis Model Year
- 2015
Hello, I recently got the 2015 3.8 rwd 102k miles and was able to change the transmission oil. I had planned on changing the oil first, then wait for the pan with filter to come (ordered already). After changing the oil (max life ATP which is rate for the sp-iv rr spec) , there is a slippage from 5th to 6th gear. When changing gear it would rev up then down then ultimately get into 6th gear. I drive faster than change to 6 then immediately 7th to bypass but obviously not ideal.
I've been reading thru the other pages about the TSB and also some YouTube videos about changing the solenoid valve. Based on the TSB I'm not quite sure which part number to get? I don't have any codes on my vehicle and reading thru other post some people state there might not be any codes?
Also would you guys recommend changing multiple solenoids? I it might be costly but if I'm going to have it disassembled, I figured might as well change if it decreases risk and I plan on keeping the vehicle for a while. Thank you
