Wont start/wont Crank
Fie6033
Please Help! Had the Oil light on in my 2015 Hyundai Genesis sedan 3.8 Ultimate Htrac, I replaced the Oil Pressure Sensor/ New NGK Laser Plugs, cleaned the Vavles, put a Oil Catch Can, after all this the car will not Start won't crank nothing! Before changing the sensor, the car started fine never had a problem not starting, replaced the Starter relay did nothing, has less then 8 month old H9 interstate battery load test was fine charged the battery over night nothing, it's like I have all other functions lights headsup display just will not crank start, don't even hear the Starter cylinoid even click, I have a check engine light and a yellow car light with a key in it, no codes, tried all 3 fobs out of ideas????
Bump. Moved to the correct forum...
And where is the form I can't find any Info?
Seems you are already here. Note the heading at the top of the page General 2015-2016 Hyundai Genesis Sedan Discussion
Your question appears to everyone but they are categorized to make searching easier. When you post a new topic you can select the forum you want it to be in.
If you look at my profile your see I only made it yesterday not even 24 hours on here????
You're in it. I moved the topic out of the community lounge (one section) and into the correct section (this one).
Not sure what you're trying to say here... The topic has been moved to the correct forum. If anyone can help, they will.
When this happens, press start button to ON then shift down to D and back up to P while having your foot on brake. Then press Start button again, it will start right up. It's either the neutral safety switch or starter I've heard
Was the starter cylinoid fried put a new starter in problem fixed
Not sure if that is the cause at this time. Just saying that this works at the time being. Still needing to take it in.
