Deebo
- May 5, 2018
Hello, Kind of new to this forum and I can sure use your help. I took my 2015 to Hyundai for the 60K service. One week after the services, the engine oil light warning came on. Took back to the dealership where they told me the the "oil sending unit" needed to be replaced. They also recommended replacing the "fuel injectors" at the same time. I had purchased an extended warranty when I bought the car. The warranty covered the "Oil sending unit" but nor the "fuel injectors". I elected to have both replaced. Picked up the car following repairs on Friday 02/03/23. On the following Thursday, 02/09/23, I as driving down a residential street and my engine light comes on and the car barely had enough power to get it off the road. Got car towed back to Hyundai who is now advising me that I need a new "Throttle Assembly" which is not covered on the extended warranty because they consider that maintenance. I am an older gal and really don't have the mechanical brain to figure this out but was able to do some research online that said the throttle body needed to be removed to replace the fuel injectors. This seems suspicious to me that the throttle body now needs to be replaced 6 days after the fuel injectors were replaced. Is it possible the mechanic failed to correctly connect the throttle body to the MASS Airflow Sensor? Or is this a legitimate repair? I'm already out $2,100 for the fuel injectors and now they want $800 to replace the throttle assembly.
Any advice would be appreciated. Thanks - Dee
