2016 Genesis Sedan 3.8 PCV location?
Tesla50
Good Afternoon, went to replace the PCV valve this morning thinking it would be a few second job but can't seem to locate it. Can anyone advise its location? better yet a pic would be great. Thank you.
Located on the back of the right hand valve/cam cover. Exhaust side. P/N 26740.
thank you, that looks like I might have to take the intake plenum off then correct?
Yes, the air box needs to come off, maybe some other items too. I did the oil/air catch can and it's a bit tough to get back there. I never removed the PCV, just the hose clamp to put on a different hose.
The hose I purchased was low permeation 5/16".
Here is a picture of PCV location under throttle body (mine is 2018 G80 3.8 V6). You just need to take off air hose that connects throttle body and air filter.
Can you spray crc into that hose?
Yes, I think it’s best to use CRC throttle body spray n air intake cleaner and dry rag to clean the lips to remove build up of carbon. But be gentle.
I think they are similar. But here is what I meant.
Is the CRC throttle body spray n air intake cleaner different from CRC intake valve and turbo cleaner ?
