21 and up G70 Lexicon amp pinout
emartinez13
Hey all,
I have a 2022 G70 Sport Prestige 3.3L and had a hard time finding out what wire is what so I could grab the signal to feed my JL audio Microsub+
Attaching a pdf with the amp connectors labeled in case it helps anyone in the future.
thanks! that will come in handy soon
Extremely helpful!
Have you been able to find any detailed info on the individual speakers? Ohm rating, RMS wattage rating, T/S specs etc...
My 2018 G80 has the same connectors at least, but I believe the pinout diagram will be different because it has a different speaker setup from the G70.
Would you happen to have access to that? I cannot find it for the life of me. Amp P/N 96370-B1600.
Hey bud was you able to find the pin out?
New here...came specifically for this pinout.
2022 Sport Prestige Siberian Ice/Black and Storm Gray.
Subwoofer upgrade using Audio Control LC2iPro
I am getting ready to try and tackle the same thing. I have done amp installs back in the day, but never like this with a AC LC2iPro. do you have any pics of your setup that I could copy. 2022 Prestige...thanks in advance!
Hello Rip,
Were you ever able to locate the pinout?
Thanks, CJ
Hello Genuine,
Were you ever able to locate the pin out.
Thanks, CJ
Does anyone know where I can track down the pin locations for a 2024 gv70 EV? I have the Lexicon amp and dual subs under the front seat. I'm assuming it's similar to previous years. I tapped pin 1,2, 16, 17 and was able to get low end signal using a small 6.5" speaker. I heard in previous years the subwoofer pins were 16,17,18,19. I tried alldata but didn't see it listed there.
Also, does anyone know what pin the high side of the RANC module is? I want to try to disable that so it doesn't interfere with the subs signal.
