Is this a good place for the remote start module?
Genesiswonderer
Title. Recently had a remote starter installed at best buy. I was exploring around and realized they had installed the brain near the obd ii port. This is under that cover. With the cover on I can't tell anything is different.
So is this a good place for a remote start module? Or would have y'all put it in a different spot? Should I be concerned with it's placement?
You can see the brain at the top left.
I would want it to be neater and not block easy access to any of the fuses.
That's what I was thinking too. Do you think it's worth trying to get it moved if everything works fine?
If you have to get someone else to do it, probably not.
