Navigation doesn't work after update
onecrappie
Title says it all. 2021 G70. Did the update via USB. Now it says "navigation is currently unavailable please check the sd card".
Do I have to update the SD card as well?
You have both an sd card and a USB method?
I thought it was one or the other.
Re-do the update...
Re-do the update...
Ended up I needed to update via SD card not usb
If you have an SD card slot, then your maps are on the SD card. You can update the software from the SD or the USB, but the maps on the SD card have to be up to date to match the software. If you have the SD slot, it's easier to just do all the updates from the card.
I went to Genesis Map Update, downloaded to my computer, downloaded to USB, downloaded to my car. It has worked great since then.
Yeah, the update itself worked fine. I was missing maps on the SD card. So had to copy-pasta them into the SD.
