Overlordexo
- Aug 10, 2023
- Genesis Model Year
- 2012
Hey there all, A friend of mine recently had an issue with his 2012 Genesis 3.8L. His AC was working normally, then one day out of the blue is stops. He took it to the dealer, who informed him that his compressor had failed.
So, as he didn't want to pay what the dealership wanted to get it repaired, we ordered the compressor, condenser, TXV. I have spent the last few days removing all of the old components and lines - flushing everything out, reinstalling all new seals and reinstalling the new compressor/condenser/txv.
I then placed the system under vacuum for about an hour, closed the manifold and let the system sit for another hour. Vacuum remained at -30 (as per the manifold gauges). So with everything looking good and the system appearing to be sealed, i charged the system with R134a (22.9+0.88oz), noted that the compressor was engaged and refrigerant was flowing thru the system. After a few moments, I noticed my low side pressure beginning to dive, while the hi side pressure remained around 225 PSI. While the low side pressure continued to dive to around 10 PSI, the high side climbed to about 250 PSI.
So to me, that indicates some side of restriction on the suction side. The EVAP was completely clear when I flushed it. Could the TXV be faulty (even though it's new) and causing this?
I currently have the vehicle connected to my recovery machine to verify that there indeed is not a leak somewhere in the system. (By weighing the recovered r134a)
Or is there something else I'm missing?
Any thoughts, ideas, suggestions would be appreciated!
