maverick6652
- Aug 14, 2014
I'd disconnect the negative cable for ten minutes and see if that resets things. During that 10 minutes, you can light incense, chant, face the sun, dance naked, or any other rituals you think may help.Every since I changed the battery on my 2013 Genesis my display has been flashing strobing. The speedometer froze at 65 mph and wouldn't move and the fuel gage showed empty. I put a OBD scanner on it doesn't show any faults. Any suggestion? It doesn't do it all the time.
Brother u get any solution????my car also same problemEvery since I changed the battery on my 2013 Genesis my display has been flashing strobing. The speedometer froze at 65 mph and wouldn't move and the fuel gage showed empty. I put a OBD scanner on it doesn't show any faults. Any suggestion? It doesn't do it all the time.
I resolved my issue. I bought a cluster on Ebay (about $100, slightly more mileage than the original) and asked a local mechanic to replace the cluster (paid $200). After the replacement, everything works fine.I have the same problem with my 2014 Genesis 3.8.
Temp, RPM, speedometer, and gas are all stock (temp is normal, rpm stuck at 1250, speed stuck at 30, gas stuck at half). Disconnected the negative cable, but no luck. Pulled the CLUSTER fuse and inserted again, no luck.
Maverick6652, could you share how you resolved this issue??
Thank you.
