Changed alternator
BKLYN
1G Genesis Coupe (2009-2016)
Changed my alternator two times, however battery light eventually comes back on. Eventually the car will start to overheat. If I turn AC on, no cold air and car eventually starts to overheat. When replacing the alternator, do I have to use an OEM part for the car to run efficiently. Will appreciate if someone has any info about this. Thanks.
Are you changing the alternator because the battery light is coming on? That light indicates a problem with the charging circuit. While often this problem is the alternator (since it is a wear item), sometimes it is something else such as the wiring or another electronic module. Always, there are troubleshooting steps to be taken to diagnose the problem before just throwing a part at it. If you are not equipped to do this diagnosis, you will need to take the car to someone or somewhere that is.
Is the overheating happening only when stopped or at slow speeds, or at high speeds? It is probably not directly related to your electrical problem, but never say never. Again, a lot more info is needed to help diagnose this problem.
Thanks a lot bro, will get it diagnosed.
