Hello 👋 Hazard lights won't turn off
TLogan
My 2012 genesis hazard lights came on just parked. How do I get them off.
Welcome. This topic has been moved out of the community lounge and into the first generation Genesis Sedan forum...
I had the same problem, Here's what I did disconnect the battery. Buy a can of CRC Electronic Cleaner unplug thr FAM and spray clean let dry. I noticed by pulling the fuse on the driver side dash in and out it caused a clicking sound under hood on the passenger side so I traced it to this relay was clicking and replace it. Hope this helps
Did you find an answer. I’m having the same issue.
I’m having same issue. I have a 12 Genesis Sedan. Did you find a solution to the hazards staying on?
I have read where replacing the FAM on your case cleaning the fam may have only worked temporarily. Is your fix still working? Thank you for your time!
